Source
alnaimi
Hi all,
any body had a LABVIEW PDF ?? :wub: i want any source related to electrical and electronics engineering :D plz help me I am requestin g some books but I didnot get them so far
Hello Alnaimi,
you should search the LabVIEW bookshelf, if you have LV 7. In 8 it is removed. But the LabVIEW help covers most everything there is to know about LV. Now if you want to digg deeper consider a LV basics course, if I'm right you can purchase those books without a course.
But why do you connect LV and electrical/electronics engineering?
LV is (almost) a full blown IDE for a programming language, and the block diagram might on the first hand look like a electrical print but there is no connection :nono:
Now for starter questions (like your previous about the amplifier), the NI forums are better.
Search on the LV learning center for the knowledge you need.
(oke the :wub: turned me over and the coffee is OK)
