LAVA 1.0 Content Posted December 26, 2006 Report Share Posted December 26, 2006 There should be a way to inherit properties and methods of build-in LabVIEW control to the properties and methods of an XControl. If XControl front panel consists of more than one control, developer should be able to choose one control to inherit from. This is a must for XControls to really be usable. Very common use case for XControls is to extend the functionality of built-in control in a much a same fashion as one can extend functionality of an OOP class. In pseudo language a user defined XControl should be able to look something like the following Class MyTreeXControl extends TreeControl implements XControl { ... } Quote Link to comment
Ton Plomp Posted December 27, 2006 Report Share Posted December 27, 2006 There should be a way to inherit properties and methods of build-in LabVIEW control to the properties and methods of an XControl. I agree, do you think it is a lot of work to read all the properties/methods of a normal control and process this into properties and methods of an XControl? with scripting off course Then if you have a XControl consisting of several controls, should you build all the controls, or just some? Ton Quote Link to comment
Michael Aivaliotis Posted December 27, 2006 Report Share Posted December 27, 2006 I agree! I have only been exposed to XControls for a short time. I consider myself a newbie rgarding XControl, however I have already come across the need for this. I sure hope NI is working on this for an upcomming release. Quote Link to comment
Jeffrey Habets Posted December 27, 2006 Report Share Posted December 27, 2006 do you think it is a lot of work to read all the properties/methods of a normal control and process this into properties and methods of an XControl? with scripting off courseThen if you have a XControl consisting of several controls, should you build all the controls, or just some? This should be possible. I'm looking into it at the moment, so lets see what comes out. Quote Link to comment
Ton Plomp Posted December 27, 2006 Report Share Posted December 27, 2006 This should be possible. I'm looking into it at the moment, so lets see what comes out. Good, a question for all: I have a framework where the developer can choose for which facade VI controls the inheritance should take place. Now in the XControl a folder %control1%.properties and %control1%.methods will be placed with the properties and methods. But several issues arise: How to get the facade VI control reference inside the property VI. A reference to the XControl is available but that is not easily parsable into the facade VIShould we pass the controls around via the display state? What about the inherited properties like 'Scales', 'Text' and 'Numeric'? I think we need them What do you think about these Items, esp. nr 1!!!! Basically I am looking for VI's that allow automatic property and method generation Ton Quote Link to comment
Ton Plomp Posted December 28, 2006 Report Share Posted December 28, 2006 What about the inherited properties like 'Scales', 'Text' and 'Numeric'? I think we need them Does anyone know how to detect the type of the inherited item? If I use a propertyitem label on a string control I get a label-reference, I haven't succeeded in determing the type using OpenG-toolkits. PJM private class generator doesn't know the classes as well. I have found out that the classID is 5 one of the low ones PJM hasn't identified. Does anyone have a clue? Ton Quote Link to comment
Jeffrey Habets Posted December 28, 2006 Report Share Posted December 28, 2006 Does anyone know how to detect the type of the inherited item?If I use a propertyitem label on a string control I get a label-reference, I haven't succeeded in determing the type using OpenG-toolkits. PJM private class generator doesn't know the classes as well. I have found out that the classID is 5 one of the low ones PJM hasn't identified. Does anyone have a clue? I'm not exactly sure what you're asking, but ClassID 5 is the Text class (GObject->Decoration->Text). Do you need the private parts of this class? Quote Link to comment
