Michael Aivaliotis Posted January 3, 2007 Report Share Posted January 3, 2007 Well, the more I work with Xcontrols, the more I realize that there is a SERIOUS lack of documentation or examples for them. Can someone shed some light on the Convert State For Save Ability and how the hell I'm suppose to freakin' use it? Quote Link to comment
LAVA 1.0 Content Posted January 3, 2007 Report Share Posted January 3, 2007 Can someone shed some light on the Convert State For Save Ability and how the hell I'm suppose to freakin' use it? I've no idea how to use it but I think it's there so that the developer could change the XControl and programs using that XControl won't break as the old XControl on the existing front panels can be converted to new versions of the XControl. Quote Link to comment
Jeffrey Habets Posted January 3, 2007 Report Share Posted January 3, 2007 Well, the more I work with Xcontrols, the more I realize that there is a SERIOUS lack of documentation or examples for them.Can someone shed some light on the Convert State For Save Ability and how the hell I'm suppose to freakin' use it? Let me shed some light.. Normally when you save your VI containing the XControl (at edit time) the State data is saved with the VI. I.e. the State data is persistent as with native controls. Now let's say you have elements in your State data that you don't want to be persistant for some reason, you could implement the Convert State For Save Ability and use this to change what ever data needs to be saved with the control. Basically you could save whatever you want by wiring the data to Display State To Save. Now, when you use this, you need to implement code in the Init ability to read and convert back the Previous State to useable data for your XControl again. Quote Link to comment
Ton Plomp Posted January 3, 2007 Report Share Posted January 3, 2007 Or more clear, you have a graph with 20 Meg of data..... you can ditch this before closing the containing vi Ton Quote Link to comment
