DAQ PCI-6024E
spacetoon34
Hello,
I want to ask how can i deal with two seperate analog input channel, because it say that an error that one of them reserver by other
although i specify the first one to CH1 and the second to CH2.
how can i solve this problem
and i want to ask if i have a digital input from a device but i connect it with analog input channel ,can i get the values of digital (1,0) by comparing the input channel with 2.5 if gratear = 1 and if less = 0 ???????
thanx,
  • 5 weeks later...
QUOTE(spacetoon34 @ Jan 15 2007, 06:10 AM)
Hello,
thanx,
you will get the values depend on the value that device support ..
QUOTE(spacetoon34 @ Jan 14 2007, 03:40 PM)
Hello,
thanx,
There is only one A/D in the card the Channels are multiplexed. If you set up a task in MAX for continuos sampling or even N number of samples, and run that in parrallel with another task, one will get the A/D First and the other will not be able to access it. The answer is to not do continuous sampling do N number and use a semaphore. Use obtain and release before and After read this will allow sharing of the resource.
Yes you can use an analog channel to simulate a digital channel, you can even get a boolean output read analog if greater than 2.5 = True.
QUOTE(van18 @ Feb 13 2007, 08:50 AM)
If you can read both analog channels in the same place of your code, you can put both channels in a DAQmx Task and read them using a DAQmx Read. The task will handle the resources so you won't need to worry about doing the locking yourself (assuming that you're only reading the task in one place).
