jzoller Posted January 15, 2007 Report Posted January 15, 2007 1. Drop a scan from string primitive on the BD. 2. Create a constant format string from the primitive. 3. Type in something useful, like "%s". The output type adapts. 4. Make the label visible on the format string constant. Change the label text, and the output types return to "dbl". Recompiling (in most forms) re-adapts the outputs to the correct types. Strange that changing the label (which is apparently largely cosmetic) changes the apparent functional output type. This problem is a bit worse in 7.1, since not all types of recompile will re-adapt the outputs. Joe Z. Quote
Ton Plomp Posted January 15, 2007 Report Posted January 15, 2007 I can't replicate this in LV 8.2 EDIT: Seeing i2dx's code, I missed the fact that you have to edit the label. sorry, Ton Quote
i2dx Posted January 15, 2007 Report Posted January 15, 2007 I can't replicate this in LV 8.2Ton I can replicate this in LV 8.20 and LV 7.1.1 Quote
jzoller Posted January 15, 2007 Author Report Posted January 15, 2007 Reported to R&D for investigation, #45EC8SVB Quote
Bjarne Joergensen Posted January 22, 2007 Report Posted January 22, 2007 Reported to R&D for investigation, #45EC8SVB It's and old bug. It is also seen in LV6.1 Bjarne Quote
