NAGWI Posted January 16, 2007 Report Posted January 16, 2007 Hi all, Does any body having waveforms recorded while doing testing?. If any, Could any body attach it here. Regards, NAG Quote
Ton Plomp Posted January 16, 2007 Report Posted January 16, 2007 Hello NAGWI, I feel a bit of a rant coming up (please be warned). When you started as a user you had some instructions on how to use these forums, on of them whas a link to: How to ask questions the smart way Of your 7 questions in 2 weeks only 1 could sort of apply to the 'smart way', meaning a full answer can be given without asking feedback questions. Your other questions were to broad or to unclear to give a meaningfull answer. So yes I have recoderded 10s of thousands of waveforms, but what do you want to do? Ton Quote
crelf Posted January 16, 2007 Report Posted January 16, 2007 I feel a bit of a rant coming up... :thumbup: Quote
NAGWI Posted January 17, 2007 Author Report Posted January 17, 2007 Hello NAGWI,I feel a bit of a rant coming up (please be warned). When you started as a user you had some instructions on how to use these forums, on of them whas a link to: How to ask questions the smart way Of your 7 questions in 2 weeks only 1 could sort of apply to the 'smart way', meaning a full answer can be given without asking feedback questions. Your other questions were to broad or to unclear to give a meaningfull answer. So yes I have recoderded 10s of thousands of waveforms, but what do you want to do? Ton I want to play with that...If possible try to understand or else leave it. -NAG Quote
Ton Plomp Posted January 17, 2007 Report Posted January 17, 2007 I want to play with that...If possible try to understand or else leave it.-NAG Hi NAGWI, I won't post the waveforms because they contain real data (measured for our clients) AND because LV has 10 (or more) VIs for creating any kind of waveform, sinus, cosinus, pink noise, flat noise. You can multiply them, divide, add or whatever. And what do I need to understand? That your lazy? I am trying to help you but it looks like you don't want to be helped. Ton Quote
crelf Posted January 17, 2007 Report Posted January 17, 2007 Does any body having waveforms recorded while doing testing?. If any, Could any body attach it here. RTFM - there are plenty of examples in the LabVIEW help - always try there first. Quote
Karl Rony Posted January 17, 2007 Report Posted January 17, 2007 I'm working on a trending application based on the LabVIEW 8.2 example Cont Acq&Graph Voltage - Write Data to File (TDMS).vi. I collect 6 analog channels of data at a rate of 100 samples/second for 45+ minutes. A loop updates the TDMS file to the hard disk every second. It works flawlessly. Quote
