Thang Nguyen Posted February 22, 2007 Report Posted February 22, 2007 Hi, I created a parent class and some child classes having the same data which is a cluster type def. In my application, I call the "create by reference" VI of parent class with the path to the "Create" VI of the child classes and pass a cluster data. After change one element in this type def, I use the apply change for the all clusters. The problem is the "type specifier VI Refnum" did not change, so I can not connect the new cluster to the call by reference node anymore. I need to update the "type specifier VI Refnum" but I don't know how to do that. Thank you in advance any help. Thang Nguyen Quote
Ton Plomp Posted February 23, 2007 Report Posted February 23, 2007 Hi Thang, right click on the specifier, select class -> Browse.... and browse for a file that matches exactly (type defs/names/required states) the dynamic VI Ton Quote
Mellroth Posted February 23, 2007 Report Posted February 23, 2007 QUOTE(tcplomp @ Feb 22 2007, 07:30 AM) Quote Hi Thang,right click on the specifier, select class -> Browse.... and browse for a file that matches exactly (type defs/names/required states) the dynamic VI Ton Or just drag the updated VI to the "type specifier VI Refnum". You might also have to right click on the "call by reference node", and select "adapt to type" (or something similar), to get the node working correctly. /J Quote
Thang Nguyen Posted February 23, 2007 Author Report Posted February 23, 2007 QUOTE(JFM @ Feb 22 2007, 03:16 AM) Quote Or just drag the updated VI to the "type specifier VI Refnum".You might also have to right click on the "call by reference node", and select "adapt to type" (or something similar), to get the node working correctly. /J To TCPLOMP and JFM: Thank you so much, I can change it now. :thumbup: . Quote
trexpha Posted February 24, 2007 Report Posted February 24, 2007 Hi Thang. You're Vietnamese ? How can you keep making Labview projects without hardwares? I'm Vietnamese too, a newbie and looking forward to have some Labview friends. Now i'm living in Russia. So if you want to keep contact with me, please add Y!M : hachiba_1985@yahoo.com. Good luck. Quote
