Bar Graph with Vertical string markers
I have to generate some bar graphs that have text as the markers and they have to be vertically aligned under each bar.... a quick check of the graphs i didnt see an easy way to do it. i am looking into using a picture control.... is there an easier/better way ? i hope i am overlooking something...
Dan
Quick thoughts - there is a bar graph example in the example finder, but that has constant labels.
You can have your own labels by using cursors and setting the cursor names to be visible or by overlaying an array over the graph and coloring it transparent. You can then control the width and number of elements shown, but the first method sounds nicer.
Check out the example of how to use annotations on a graph.
C:\Program Files\National Instruments\LabVIEW 8.2\examples\general\graphs\Programmatically Annotate a Graph.vi
I thought this was pretty cool when I first learned of it.
-James
QUOTE(James N @ Mar 2 2007, 08:38 AM)
-James
Ben , James , Yan
Thanks for the input , after looking into this a little more i have decided to just run with the picture control as i also need to change the bar colors depending on the value...
Have a Great Weekend
Dan
