alnaimi Posted March 3, 2007 Report Posted March 3, 2007 Hi all , I know i am noisy but LAVA is my main source to learn , Well , I need a help in this program , suppose I want to build a program to teach kids any program lets say add 2 numbers ok? I want this program to be user freindly I mean the kid must enter his name first and class # , so how can I do it??? I mean a msg appears to user to enter his/her name , just that any help?? :thumbup: thnxxx Quote
AnalogKid2DigitalMan Posted March 3, 2007 Report Posted March 3, 2007 From block diagram, select Dialog & User Interface Functions, then Prompt User for Input function (an Express vi) alnaimi: May I suggest as part of your LV learning, take the time to go through every function pallate available to you and browse through each of them to see what canned functions are available. Not that you should build a vi around them to test and try each one, but rather let what is available to sink into your mind. Then when you have a task to accomplish, draw on your memory to say- ah, yes, I remember seeing a Max and Min function for an array- that could be of use for what I have to do. Quote
alnaimi Posted March 3, 2007 Author Report Posted March 3, 2007 Thanks a lot SIR :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: Will do what u have said,,, but in this case the msg will be dispalyed for infinity should I put in loop??? that appears once !!! Quote
LAVA 1.0 Content Posted March 4, 2007 Report Posted March 4, 2007 Some free resources for you... http://www.ni.com/academic/lv_training/how_learn_lv.htm http://www.ni.com/academic/ http://zone.ni.com/devzone/cda/tut/p/id/5054 Quote
