Sherif Posted March 26, 2007 Report Posted March 26, 2007 Hello .., In one of the Detection theories, it's required to Count the Number N & compare it with M ;where N = Number of received pulses at receiver side. (Original Pulses Transmitted + Superimposed noise from the Channel) M = Certain No. of Pulses (pre-specified). Actually i have no Problem in counting the M or even N but the Problem in the reset of the Counter. I used the Triggered Counter to Count the Value of N, and calculate the value of M Using a Formula Block. then i used a comparator to compare between two signals N & M. For example let M be = 10 and The counter start Counting the value of N for ex. 0,1,2,3,4,5,6....and so on when N becomes larger than or equal M (N>=M) then the Output of the Comparator will be One. Now i need to reset the counter of N when the Output of Comparator becomes One and at the same time accumulate these Outputs of comparator SUch that when the Value Of N Becomes = 10 again the counter of N reseted and start counting again from zero while adding One to the counted Output of the comparator. Quote
Nullllll Posted March 27, 2007 Report Posted March 27, 2007 I guess u can use formula node will wait the experts of LAVA 2 answer u Quote
Eugen Graf Posted March 27, 2007 Report Posted March 27, 2007 I never use express VIs, because I don't know whal happens there. I prefer only simple VIs. Can thisone help you? Eugen Quote
Sherif Posted March 28, 2007 Author Report Posted March 28, 2007 *Thank you Nulllll you are right. *For you Eugen Graf Thank you so much it really helped me alot you can't imagine Now it's counting ... Hope i could help you oneday Thanks alot i just need a good tutorial for the LabView Cause i don't have one or even Manual if you Can direct me i'd be greatfull Best regards Sherif Farouk Quote
