alukindo Posted April 3, 2007 Report Posted April 3, 2007 Hi: I was wondering whether re-entrant VI clones, newly introduced in LabVIEW 8, negate the need to launch parallel VI instances that need to show front panels from a VI template. I have yet to try this new feature and figured that my experimentation would save some frustation by tapping from the experience of other LabVIEW users. Thanks Anthony L. Quote
Jim Kring Posted April 3, 2007 Report Posted April 3, 2007 QUOTE(alukindo @ Apr 1 2007, 08:07 PM) Hi:I was wondering whether re-entrant VI clones, newly introduced in LabVIEW 8, negate the need to launch parallel VI instances that need to show front panels from a VI template. I have yet to try this new feature and figured that my experimentation would save some frustation by tapping from the experience of other LabVIEW users. Thanks Anthony L. Personally, I like the reentrant VI clone approach. I recently wrote a little article called http://thinkinging.com/2007/03/29/reentrant-vi-clone-name/' target="_blank">Reentrant VI Clone Name that has some info that you might find useful. Also, in the article's comments, there is a brief discussion of the differences between the *.vit and reentrant VI approaches. Quote
alukindo Posted April 4, 2007 Author Report Posted April 4, 2007 Jim Kring: Thanks for pointing me to that article. I had yet to compile an executable and have just realized that the *.vit file could not be readily added to the project. Anthony L. Quote
Jim Kring Posted April 4, 2007 Report Posted April 4, 2007 QUOTE(alukindo @ Apr 2 2007, 07:06 PM) Jim Kring:Thanks for pointing me to that article. I had yet to compile an executable and have just realized that the *.vit file could not be readily added to the project. Anthony L. I'm glad it helped. BTW, you can add a VIT as a subVI of another VI (or add all your VITs as subVIs of a VI called "All Dynamic VIs.vi" or similar) and then add this VI as a dynamic VI of your build. Hopefully this will let you build your EXE. Also, if your end deliverable is an EXE, it's best to create your build rule early and try to make sure that your application is always working in both source and EXE form. This is a lesson that most learn the hard way. Cheers, Quote
LAVA 1.0 Content Posted April 4, 2007 Report Posted April 4, 2007 CITATION(Jim Kring @ Apr 3 2007, 04:13 AM) Also, if your end deliverable is an EXE, it's best to create your build rule early and try to make sure that your application is always working in both source and EXE form. This is a lesson that most learn the hard way. I second Jim in this recommendation ! I am part of those who learn this the hard way There are lots of tools & materials that will help you developping code that works the same both in source and EXE ; time spent to learn about these tools will be well-invested Quote
