tibobo Posted April 25, 2007 Report Posted April 25, 2007 Helloooo, I use LVOOP, 8.2.1 with app builder on a G4 mac. I build executables which contain objects and dynamic VIs created using LVOOP. I used the "do not disconnect type efinitions" option. The executable crash at load time. Is there any way to know where the crash comes from ? Building of executables is quite long so I would like to find a nice strategy to find out the cause of the crash... Thanks for your help ! Boris Quote
Aristos Queue Posted April 25, 2007 Report Posted April 25, 2007 QUOTE(tibobo @ Apr 24 2007, 03:14 AM) The executable crash at load time. Is there any way to know where the crash comes from ?Building of executables is quite long so I would like to find a nice strategy to find out the cause of the crash... I can't say what is wrong with your particular build. The known issues for 8.2.1 recommends that if your build does not work, you should try changing to Do not disconnect type definitions or remove unreferenced members on the Additional Exclusions page of the Application Properties dialog box. If you are willing to share your app, please contact NI tech support and file a bug report so we can debug your app better. Quote
PJM_labview Posted April 25, 2007 Report Posted April 25, 2007 QUOTE(tibobo @ Apr 24 2007, 01:14 AM) Helloooo,I use LVOOP, 8.2.1 with app builder on a G4 mac. I build executables which contain objects and dynamic VIs created using LVOOP. I used the "do not disconnect type efinitions" option. The executable crash at load time. Is there any way to know where the crash comes from ? Building of executables is quite long so I would like to find a nice strategy to find out the cause of the crash... Thanks for your help ! Boris Since LV 8.0, you can build applications with remote debugging enable (which allow you basically to debug a build app). If this option is also available for mac, I would suggest you use this. PJM Quote
tibobo Posted April 25, 2007 Author Report Posted April 25, 2007 QUOTE(PJM_labview @ Apr 24 2007, 03:17 PM) Since LV 8.0, you can build applications with remote debugging enable (which allow you basically to debug a build app). If this option is also available for mac, I would suggest you use this. I tried remote debugging, but labview crashes ("fatal error occured during operation, closing connection") during connection to the remote application (after many warnings such as : 'The class expected to be at "Macbeth:Users:boris:Desktop:builds:projet:My Application:Application.app:User.lvclass" was loaded from "Macbeth:Users:boris:Desktop:builds:projet:My Application:Application.app:AppContents_ppc.llb:User.lvclass".') QUOTE(Aristos) The known issues for 8.2.1 recommends that if your build does not work, you should try changing to Do not disconnect type definitions or remove unreferenced members on the Additional Exclusions page of the Application Properties dialog box. I used this option without success. QUOTE(Aristos) If you are willing to share your app, please contact NI tech support and file a bug report so we can debug your app better Could you send me a message to let me know the "procedure" ? Thanks for help :worship: Boris Quote
Tomi Maila Posted April 25, 2007 Report Posted April 25, 2007 QUOTE(tibobo @ Apr 24 2007, 09:10 PM) Could you send me a message to let me know the "procedure" ? Follow the link below and select call NI or email NI from the options in the page. http://sine.ni.com/apps/utf8/niae_asc.main''>http://sine.ni.com/apps/utf8/niae_asc.main' target="_blank">http://sine.ni.com/apps/utf8/niae_asc.main EDIT: It seems they still don't have 8.2.1 in the list of LabVIEW version.... Select 8.2 instead. If a NI person is reading this thread, you know what to do. The local NI support will then help you further. Try to make your bug report as detailed as possible so it's easier to debug. Provide all the needed files to repeat the problem and provide step by step instructions what to do to get the problem to appear. Tomi Quote
tibobo Posted April 25, 2007 Author Report Posted April 25, 2007 QUOTE(Tomi Maila @ Apr 24 2007, 06:17 PM) The local NI support will then help you further. Try to make your bug report as detailed as possible so it's easier to debug. Provide all the needed files to repeat the problem and provide step by step instructions what to do to get the problem to appear. Thanks Tomi, Aristos and PJM. I'll do that asap tomorrow (the night is falling here !...) and post something here once the problem killed ! 'night !... Boris Quote
