2d array into 1d array
You forgot to mention what data type is your original image that you need to convert and what kind of 2d array and 1d array do you need to convert your image to. Please provide this information. It would help if you could specify the needed data types in LabVIEW code.
Tomi
QUOTE(kate @ Apr 24 2007, 03:21 AM)
hi there,
I need some help to convert image to 2d array and 2d array into 1d array?
if the image has 24 bits, I need to convert it to grayscale 8-bits
Do you have the IMAQ Vision toolkit? It is an add-on NI product. I would recommend you get it if you don't already have it; (it is expensive though and needs separate paid, run-time licence as well for executables).
There are functions to convert Image buffer to 2d array as well as functions to cast an image to another type. These are optimized for speed when dealing with large image buffers.
Neville.
