Thang Nguyen Posted May 1, 2007 Report Posted May 1, 2007 Hi, Could you please tell me how to work with timer if we use GOOP? For example, I want to run a pump for 5 sec. At the same time I have to do data acquisition. I have a process VI run at the behind to read data already. But I don't know how should I work with the timer, what is the best template for this case? Thank you so much, Thang Nguyen Quote
Kurt Friday Posted May 2, 2007 Report Posted May 2, 2007 QUOTE(Thang Nguyen @ May 1 2007, 06:20 AM) Hi,Could you please tell me how to work with timer if we use GOOP? For example, I want to run a pump for 5 sec. At the same time I have to do data acquisition. I have a process VI run at the behind to read data already. But I don't know how should I work with the timer, what is the best template for this case? Should I use the timeloop in this case? This is not a strict real time application. Thank you so much, Thang Nguyen Hi Thang Have you looked at the pump demo that is included in the GOOP Developer examples, take a look, it is a fairly complete example of a pump driver that can interface to different types of IO. Quote
