Control 8 machines w/same program over net?
Hello all,
I am trying to decide what would be the easyest and most reliable way to control several machines that are running the same test program from a remote machine running a master program. Data Sockets? VI server? Web server?
All Ideas Welcome.....
:wacko: :worship: :throwpc:
QUOTE(Darren2 @ May 1 2007, 03:16 PM)
VI Server will have the richest protocol for controlling (start up, shutdown, passing data) the VIs. Anything else will require you to develop your own protocols (such as passing a particular value over DataSocket and having a VI on the other end listen for that value and then interpret what needs to be done). With VI Server the functionality for opening, calling and closing a VI are already well-defined APIs.
QUOTE(Darren2 @ May 1 2007, 10:16 PM)
Hello all,
I am currently planing a test system, which has 5 nodes (cRIO) and one master (IPC). I am not yet sure, if I should choose TouchPanels for the slave control, or a *small* IPC, but I am allmost sure, that I will use the cRIOs.
