Ton Plomp Posted May 10, 2007 Report Posted May 10, 2007 Hi alnaimi, this cod should work: http://forums.lavag.org/index.php?act=attach&type=post&id=5778 Let me know if there's anything you don't get. Ton PS you used the wrong graph type (normal graph instead of XY graph) Quote
alnaimi Posted May 10, 2007 Author Report Posted May 10, 2007 here is the graph ! plz check it , It does not give me the correct graph . plz check the both photos , The one called lab 4 is your solution and the photo called noora is the normal solution i attached b4.. plz help Quote
alnaimi Posted May 10, 2007 Author Report Posted May 10, 2007 i ahve modified the pre post , the lab is there Quote
Mellroth Posted May 10, 2007 Report Posted May 10, 2007 QUOTE(alnaimi @ May 9 2007, 03:38 PM) Quote i ahve modified the pre post ,the lab is there Hi alnaimi, I think you have wired the arrays into the bundle nodes in the wrong order. The upper terminal of the bundle node is the x-axis, and the lower is the y-axis. Enable context help, and put the mouse cursor on the graph terminal to get information about how to input data to the graph. Some comments 1. its generally a good idea to make all code visible on the screen, maybe your resolution is above mine, but there is very much free space in your diagram. Keeping the diagram smaller makes it much more easy to debug and/or understand. 2. try to keep wires from left to right, increases readability and makes debugging easier 3. try to keep wires straight, i.e. with less bends (increases readability) 4. try to avoid crossing of wires as much as possible, increases readability 5. do you really have to update VGS in every loop iteration, it seems like this could be done before you enter the loop? Good luck /J Quote
alnaimi Posted May 11, 2007 Author Report Posted May 11, 2007 THNXXXXXXXXXXXXXXXXXXX ALL My VI is working WELL THNXXX LAVA Quote
Dirk J. Posted May 11, 2007 Report Posted May 11, 2007 QUOTE(alnaimi @ May 10 2007, 03:57 PM) Quote THNXXXXXXXXXXXXXXXXXXX ALLMy VI is working WELL THNXXX LAVA well, after all we've been through, do you mind telling us wat solved your problem? Quote
