Open file and Read file may occur at same time
Scenario of a given program I'm debugging:
There's a file called Howdy.txt. It either has 7 characters in it or nothing.
Parallel loops...
Loop 1 writes to Howdy.txt file every 2 minutes to 30 minutes.
Loop 2 opens up Howdy.txt every 1000mS and looks at it - to see if it's been written to. This happens all the time, 24/7.
With this scenario, it appears there's a small chance the file can be open at the same time in two places. Is this common? Can it cause problems?
The VI's are Write Characters To Fle and Read Characters From File.
Thanks!
Richard
QUOTE(BrokenArrow @ Jun 19 2007, 09:03 AM)
Parallel loops...
Thanks!
Richard
Provided they both use seperate "opens" and file ref's AND ther is only one writter*, you should be OK.
The file system (as realized throught the LV API's) track the file pointer seperately for each ref.
* There was a bug in LV 7.X where LV could mix up the file ref nums (which is a big problem if the two files are data log files of different types! You do not want to try and untagle one of these.)
Ben
QUOTE(Ben @ Jun 19 2007, 09:09 AM)
Ben,
By "use seperate "opens"" do you mean are the VI's different that do the opening? There's definately one write.
QUOTE(tcplomp @ Jun 19 2007, 09:14 AM)
A better solution is the fileinfo primitive:
If I were you I'd use a messaging system, but since you are debugging most likely you inherited the code :headbang:
Ton
That's a great idea Ton. That way, it's not opening and closing the file just to see if it has changed. Or, if it does open it, at least it's a different open as Ben recommended.
-Richard
p.s. Is writing to a file a common way to share a variable? (keep in mind this is 5.1)
ZITAT(BrokenArrow @ Jun 19 2007, 03:03 PM)
Parallel loops...
You can do this when you open the file in loop 2 only as "read only". Then it should work.
Wolfram
