calculating elapsed time (S.O.S)
ZITAT(engineer123 @ Jun 20 2007, 08:43 AM)
I have a problem in calculating the time difference between 2 events.
Can any one see the attached VI because the difference is not correct.
Thanks in advance.
The calculated time difference seem to be correct. So I don't know where the problem is.
Wolfram
QUOTE(engineer123 @ Jun 20 2007, 08:43 AM)
Thanks in advance.
I'm not sure I understand what you are trying to do.
The VI you posted work "as it should" -of course- but maybe it doesn't run as you think it should.
I think you should run it once in highlight mode to see what happens.
My guess is that you want your VI to keep runing until you press button 1 and button 2 and to tell you how much time has elapsed between these 2 events, am I correct ?
I tried to make as few changed to your code as I could to make this work how I assume you want it to work. It now calculates the elapsed time between a press of "Boolean 1" and a press of "Boolean 2".
