i2dx Posted July 25, 2007 Report Posted July 25, 2007 Hi Folks, I need a hint / resp. I need to be sure: If I use the "Open VI Reference" primitive I can wire an application reference to ensure that all VIs run in the same application instance. If I use static VI references in my LV 8.2.1 project and use these references to dynamically start and stop VIs through VI Server, do these VIs run in the same application instance as the VI where I have placed the static references? Quote
Yair Posted July 25, 2007 Report Posted July 25, 2007 When using a static VI reference, the VI is held in memory just like a regular subVI you would call from the calling VI, so the answer would be yes. You can actually double click the reference to open the subVI. At least, that's the way it worked prior to 8 and I don't suppose the project changed that. Quote
