BitPack Tools Posted September 23 Report Posted September 23 (edited) Hi everyone, I just released a small LabVIEW tool that allows you to embed custom data into PNG files and extract it back. The image remains fully viewable while carrying hidden data. Optionally, the data can also be exported in XML format. Included VIs: Encode VI – Appends data to a PNG file or exports to XML. Decode VI – Retrieves the embedded data from a PNG file, including XML if used. Key Features: Preserve image appearance while storing hidden data. Optional XML export for structured data. Combine images and related data in a single portable file. Store hidden notes or annotations without affecting the image. Possible Use Cases: Data + Image packaging for measurement results. Metadata storage (experiment details, settings, version info). Lightweight data transport. Scientific experiments or field work with images + sensor readings. Archiving visual and numerical data together. Secure sharing of proprietary information. Dependencies: The tool uses two VIs from the MGI Library (BSD 3-Clause License). For simplicity, these VIs are included directly in the repo. You can check it out and download it here: https://github.com/BitPackTools/pixpack Feedback and suggestions are welcome! Edited September 23 by BitPack Tools Quote
ShaunR Posted September 23 Report Posted September 23 It doesn't seem to produce a valid png (either as XML or "not encoded"). I've changed the extension name of the produced file (.notaping) because the web interface will not allow uploading as a png. PicPack_Embedded.notapng Quote
BitPack Tools Posted September 24 Author Report Posted September 24 Hi ShaunR, Thanks a lot for checking it out and giving feedback! You were actually right — the issue came from LabVIEW’s “prepend array or string size” option in the Binary Write VI, which adds the array length (U32) at the start. That’s why the file didn’t start with a proper PNG signature. I’ve fixed it, and now the decode VI also returns the image separately, so it should work nicely even in LabVIEW. Really appreciate you taking the time to try it! Just a note: this isn’t a strictly valid PNG, since the extra data isn’t stored in chunks but appended after IEND. Still, image processing tools usually don’t mind, as they only read up to IEND. Quote
ShaunR Posted September 24 Report Posted September 24 (edited) OK. Now we're cooking with gas. Some minor (and one major*) comments. Data does not survive a copy operation.* Error in (No error) shouldn't be required. Add a document that states the licence conditions that you are distributing under (e.g. MIT, BSD, Creative Commons etc) Use a Hex Encode and Decode you have written. Don't use the two MGI utilities. Make your logo smaller. With regards #4. You are only using two MGI utils to convert to and from hex chars. That can easily be done natively without requiring installation of a 3rd party toolkit. Using those two requires the end user add an additional copyright statement to their binary distribution that they may not be aware of (were you?). Save them (and yourself) the copyright issues. Quote * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. If you are going to use 3rd party toolkit, require they install them as a dependency then you will not have copyright issues ... but you don't need it for this. Edited September 24 by ShaunR Quote
BitPack Tools Posted September 24 Author Report Posted September 24 Thanks again for taking the time to review and comment! About the hex encode/decode: good point. Those two small functions originally came from the MGI Utilities, which are under the BSD-3-Clause license. I’ve copied them into the repo together with the license notice, so there is no hidden copyright issue and no need for users to install the full toolkit (as also noted on GitHub). The Error In terminal is intentionally required — that’s by design and will remain so. You also mentioned “Data does not survive a copy operation”. Could you clarify or give me an example? I’d like to reproduce that issue, since I haven’t encountered it myself. Thanks again for helping improve this! Quote
ShaunR Posted September 24 Report Posted September 24 2 hours ago, BitPack Tools said: so there is no hidden copyright issue There is. If they create an executable they need to add the copyright to their documentation or distribution in some way as the licence is contained in the MGI VI's description. 2 hours ago, BitPack Tools said: You also mentioned “Data does not survive a copy operation”. Could you clarify or give me an example? I’d like to reproduce that issue, since I haven’t encountered it myself. Example_1.vi Quote
BitPack Tools Posted September 24 Author Report Posted September 24 I’ve added it, the license is now available on GitHub. I can’t open the VI you sent — I’m using LabVIEW 2020. Quote
BitPack Tools Posted September 24 Author Report Posted September 24 The password is the filename, meaning the filename carries the payload’s password. I am fully aware of the drawbacks of this approach. Users can just as easily forget the given password as they can rename the file—which is why it didn’t work for you, though you probably knew that 😃. The solution is freely modifiable, and if there is a real need, I can add an option for a custom password. 🙃 Quote
ShaunR Posted September 25 Report Posted September 25 13 hours ago, BitPack Tools said: I am fully aware of the drawbacks of this approach. Your customers also need to be aware of any drawbacks and caveats. If the filename is used as a key for an encryption scheme then perhaps it should be mentioned in the documentation and, additionally, what scheme you are using. I think this will be the most common reason people will seek support from you. I won't harp on much more about the MGI licence but just say, finally, I don't think you fully understand the issue, which could have been completely avoided. Just for reference, I have attached my test harness from above in LV2019. Example_1.vi Quote
BitPack Tools Posted September 26 Author Report Posted September 26 https://github.com/BitPackTools/pixpack Just released PixPack 1.1.0 Removed MGI dependencies → replaced with faster native search (no external toolkit required) Dropped RC4 (Flatten/XML) encryption, only simple byte negation remains Added support for embedding/extracting external files via 7zr.exe (password required) New VIs: PP.PNG.File.Encode.vi, PP.PNG.File.Decode.vi, Write.Encrypted.7zPayload.vi, Read.Decrypt.7zPayload.vi Added a small GUI for file embedding, so it also works in built applications First versioned release: 1.1.0 README and license updated on GitHub. Note: Compatibility with earlier builds was not maintained — the changes were big enough that it made more sense to simplify and move forward. Quote
ShaunR Posted September 27 Report Posted September 27 (edited) Nice. While I was trying to figure out why I wasn't getting the image (because there is a boolean to return it ); I noticed you used a temporary file for the png image. There is a better option in the Web Services palette which means you can directly convert a byte string into a LV image without an intermediary file: As you now have two different connector-panes for different modes of operation (text and file embedding), you might want to consider whether a polymorphic VI would be useful for their adapt-to-type feature. Finally. If you are going to distribute the 7zip binary rather than requiring the end user to download it; don't forget to heed the copyright. They want you to add the actual LGPL text rather than reference a URL. Quote Redistributions in binary form must reproduce related license information from this file. Edited September 27 by ShaunR Quote
BitPack Tools Posted September 29 Author Report Posted September 29 Good idea, thanks – I applied the change and the code is simpler now. By the way, could you share what exact problem you had with the temporary file? I still have other parts in the code that rely on it, so it would be useful to know if there are any pitfalls. The 7z license is also attached. Quote
ShaunR Posted September 29 Report Posted September 29 1 hour ago, BitPack Tools said: By the way, could you share what exact problem you had with the temporary file? No problem. I just hadn't created a TRUE boolean so that the image is returned (default is false). I usually expect indicators to return things, except if there is an error, and not be conditional on other inputs. Quote
BitPack Tools Posted September 29 Author Report Posted September 29 Okay, glad to hear there's no problem! Quote
