Vandy_Gan Posted October 11 Report Posted October 11 Hello everyone, I want to implement a similar function in the image. You can add or set icons in other columns of the tree control. How should I do this function? thanks a lot. Quote
hooovahh Posted October 11 Report Posted October 11 You've probably already found some stuff but here is an old thread that talks a bit about it. It is an unofficial feature that NI seemingly never finished, or never documented. INI keys can help you, or I think you can copy a MCLB that has the feature enabled. Another solution I've done in the past is to have a 2D picture box on top of the control, then having that be an image that you can set. This gets way more complicated with scrolling, and resizing windows, but it allows you to have glyphs that aren't the default size which is also what I wanted. Quote
Vandy_Gan Posted October 13 Author Report Posted October 13 On 10/11/2025 at 7:03 PM, hooovahh said: You've probably already found some stuff but here is an old thread that talks a bit about it. It is an unofficial feature that NI seemingly never finished, or never documented. INI keys can help you, or I think you can copy a MCLB that has the feature enabled. Another solution I've done in the past is to have a 2D picture box on top of the control, then having that be an image that you can set. This gets way more complicated with scrolling, and resizing windows, but it allows you to have glyphs that aren't the default size which is also what I wanted. Hi Hooovahh, Thanks for your answer. the vi's link of example is unreachable, and the picture that I uploaded is used tree control, also, I think multilistbox and tree control would use similarar way to achive multiple columns glyphs , but I don't have good thoughts right now, could you provide a better direction? the labview version that I use is 2020. Thank you again. Quote
hooovahh Posted October 13 Report Posted October 13 This still works. This is still a MCLB not a tree. I'm unsure if the feature exists for trees. Quote
Zou Posted October 13 Report Posted October 13 Instead of using a little Glyph image, it's a lot easier to set the background color of a cell in the result column. Quote
