Vandy_Gan Posted 5 hours ago Report Posted 5 hours ago Hi everyone, there was a code's picture that reedit ctl‘s Booltext and saved to new file, it workd ok in development environment,but new ctl could be invalid when it run as exe at runtime ,I did not how to solute it.Could you give me some suggestion. Thank you. Quote
ensegre Posted 3 hours ago Report Posted 3 hours ago I do not know what is a LV stringApp instance, but I doubt that it is exactly a loadable control. What are you trying to achieve exactly? Quote
Vandy_Gan Posted 2 hours ago Author Report Posted 2 hours ago 42 minutes ago, ensegre said: I do not know what is a LV stringApp instance, but I doubt that it is exactly a loadable control. What are you trying to achieve exactly? ensegre, thank you for your reply, I want to achieve one application(exe) that has the function: edit a template boolean ctl's BoolText and save to new boolean ctl by programming. And the code works fine in development environment, but it is invaild at runtime when used the exe built. Quote
ensegre Posted 1 hour ago Report Posted 1 hour ago I would have said why don't you use Save.Instrument which is a public method, but I see that it is not supported in runtime, and that is stated expressly. A fortiori, a private method which "must wait until the user interface isidle" might be a completely IDE thing. Quote
