bbean Posted August 19, 2007 Report Posted August 19, 2007 Is there a way to get a cluster of all the properties for a graph? I would like to store most of the properties of a graph to file and then recall them later in. It seems like there should be an easier way than building a giant cluster manually and saving it to an INI file. I've found a "Plot Attributes" cluster that can be retrieved utilizing the event structure. http://forums.lavag.org/index.php?act=attach&type=post&id=6674 But I haven't found a way to pump this cluster back into the graph without unbundling the entire thing an manually wiring up each property to a giant plot property node. http://forums.lavag.org/index.php?act=attach&type=post&id=6675 Quote
Yair Posted August 19, 2007 Report Posted August 19, 2007 Try taking a look at Property Saver. Another option, since you already have the cluster, is using the OpenG variant config VIs or MGI's save anything VIs which allow saving and loading arbitrary clusters. Quote
bbean Posted August 20, 2007 Author Report Posted August 20, 2007 QUOTE(yen @ Aug 18 2007, 02:49 PM) Quote Try taking a look at http://www.kshif.com/lv/index.html' target="_blank">Property Saver. Just what I was looking for. Thanks. Quote
