Retrieving SubVI Memory Usage at Runtime
Is there a VI property/method or way to return the currnt memory usuage of a VI that is running? How does the profiler accomplish this?
The reason I need to do this is that I want to monitor the memory usuage of template vi instances that I run. If I start the profiler before I run the application to track memory usage, the instances of the VIs are shown when they are opened, but they always show 0k for their use.
I was also contemplating creating a graphical memory profiler....has this been done before in LV?
B
QUOTE(bbean @ Aug 23 2007, 04:45 PM)
B
There is a VI property: metrics that has
* size of BD
* size of FP
* code size.
I am not sure if it will work on a running VI.
Neville.
QUOTE(Neville D @ Aug 23 2007, 08:08 PM)
* size of BD
* size of FP
* code size.
Neville.
BD and FP size are available during runtime but Data Size is not. BD and FP don't seem to change while the VI is running
