Justin Goeres Posted August 25, 2007 Report Share Posted August 25, 2007 I'm finally getting around to using the 3d Picture Control for something "serious," and I feel like I'm running up against a bit of a learning curve. There are two things I'd like to do, and I feel like they should be easy: (1) I would like to show a set of XYZ coordinate axes on my 3d Picture Control to show where {0,0,0} is, and which way the unit vectors point. Is there some way to do this easily, or do I have to build them out of 3d object primitives? (2) I'm confused by the ModelView Matrix and Projection Matrix properties. What I would like to do is reset the camera view to a certain position when the user clicks a "Reset Camera" button. It seems like one of these should work (and I'm familiar with orthogonal transformations, thank you very much ), but I seem to be getting unexpected results. Thanks! Quote Link to comment
Grampa_of_Oliva_n_Eden Posted August 25, 2007 Report Share Posted August 25, 2007 QUOTE(Justin Goeres @ Aug 24 2007, 04:42 PM) I'm finally getting around to using the 3d Picture Control for something "serious," and I feel like I'm running up against a bit of a learning curve. There are two things I'd like to do, and I feel like they should be easy:(1) I would like to show a set of XYZ coordinate axes on my 3d Picture Control to show where {0,0,0} is, and which way the unit vectors point. Is there some way to do this easily, or do I have to build them out of 3d object primitives? (2) I'm confused by the ModelView Matrix and Projection Matrix properties. What I would like to do is reset the camera view to a certain position when the user clicks a "Reset Camera" button. It seems like one of these should work (and I'm familiar with orthogonal transformations, thank you very much ), but I seem to be getting unexpected results. Thanks! I don't know if this will help but... Back in the LV 3d thread I posted some code that was based on the public beta version of the 3-d picture. It included axis (that I created using a cone for the arrow and a long thin cylinder for the axis). If that code still opens in the new version ( don't know PC crashed lost the source) you maybe able to start with that. At least the official relseas version has help on the VI's the public beta had no help at all! Ben Quote Link to comment
Justin Goeres Posted August 25, 2007 Author Report Share Posted August 25, 2007 QUOTE(Ben @ Aug 24 2007, 01:47 PM) Back in the LV 3d thread I posted some code that was based on the public beta version of the 3-d picture. Linky? I searched before (and just now) but didn't come up with anything. Quote Link to comment
Grampa_of_Oliva_n_Eden Posted August 26, 2007 Report Share Posted August 26, 2007 QUOTE(Justin Goeres @ Aug 24 2007, 05:17 PM) Linky? I searched before (and just now) but didn't come up with anything. http://forums.lavag.org/Special-LabVIEW-ve....html&st=30 post# 38 It does not open in LV 8.2.1 but it looks like the axis sub-VI are still intact. It'll take some work. The original code was just "sand-box" code. http://forums.lavag.org/index.php?act=attach&type=post&id=2597 I found most of this missing VI's in C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\picture\3D Picture ControlOld 3D Toolkit.llb If you get a basic axis working could you post back? Ben Quote Link to comment
Justin Goeres Posted August 26, 2007 Author Report Share Posted August 26, 2007 I made some progress. QUOTE(Justin Goeres @ Aug 24 2007, 01:42 PM) (2) I'm confused by the ModelView Matrix and Projection Matrix properties. What I would like to do is reset the camera view to a certain position when the user clicks a "Reset Camera" button. It seems like one of these should work (and I'm familiar with orthogonal transformations, thank you very much ), but I seem to be getting unexpected results. As usual, the answer was simpler than I expected. http://forums.lavag.org/index.php?act=attach&type=post&id=6757''>http://forums.lavag.org/index.php?act=attach&type=post&id=6757'>http://forums.lavag.org/index.php?act=attach&type=post&id=6757 My problem was that Setup Camera is an Invoke Node, while I was stubbornly scouring the Property Nodes for the same functionality . I now have a couple VIs that draw a set of axes, as well. I will clean them up in the next few days and post them. Quote Link to comment
