JReiner Posted September 8, 2007 Report Share Posted September 8, 2007 Hi All, This is my first post to this great forum; I'm so glad that I have this resource. I'm currently using the Base Development System ver. 8.2.1. According to NI this package lacks event based programming features. In fact if I look at the 'structures' palette there is a blank space where the event structure would be in the full version. Now, if I take a look at the templates NI provides when you invoke 'New...' from the file menu I find a framework named "Top Level Application Using Events." Clicking on this creates a little VI with an event structure and a stop button. When I run this it behaves just as expected. Does anybody have a sense for what kinds of problems I'll run into if I decide to develop and event based VI with the base package? Is it worth the trouble? Regards, Josh Quote Link to comment
TobyD Posted September 8, 2007 Report Share Posted September 8, 2007 QUOTE(JReiner @ Sep 7 2007, 09:44 AM) Hi All,This is my first post to this great forum; I'm so glad that I have this resource. I'm currently using the Base Development System ver. 8.2.1. According to NI this package lacks event based programming features. In fact if I look at the 'structures' palette there is a blank space where the event structure would be in the full version. Now, if I take a look at the templates NI provides when you invoke 'New...' from the file menu I find a framework named "Top Level Application Using Events." Clicking on this creates a little VI with an event structure and a stop button. When I run this it behaves just as expected. Does anybody have a sense for what kinds of problems I'll run into if I decide to develop and event based VI with the base package? Is it worth the trouble? Regards, Josh My understanding is that existing code will run with the added functionality, but you will not be able to save any edits. You might want to try saving/building with some basic modifications before getting too far into a project. Quote Link to comment
JReiner Posted September 8, 2007 Author Report Share Posted September 8, 2007 QUOTE(TobyD @ Sep 7 2007, 01:02 PM) My understanding is that existing code will run with the added functionality, but you will not be able to save any edits. You might want to try saving/building with some basic modifications before getting too far into a project. Actually, I found that when right-clicking on the event structure there is no option to add an event case. Thanks for your help. Regards, Josh Quote Link to comment
Neville D Posted September 8, 2007 Report Share Posted September 8, 2007 There's no way you can develop code using the Event Structure if only have Base Edition.. existing code will run, thats all. you will have to spring for the Professional Edition. Neville. Quote Link to comment
Justin Goeres Posted September 8, 2007 Report Share Posted September 8, 2007 QUOTE(Neville D @ Sep 7 2007, 10:58 AM) you will have to spring for the Professional Edition. Actually, I believe the Event Structure is included in http://www.ni.com/labview/how_to_buy.htm#compare' target="_blank">both the Full and Pro versions (although I could be mistaken). Quote Link to comment
