Event Based Programming with the Base Development Package
Hi All,
This is my first post to this great forum; I'm so glad that I have this resource.
I'm currently using the Base Development System ver. 8.2.1. According to NI this package lacks event based programming features. In fact if I look at the 'structures' palette there is a blank space where the event structure would be in the full version.
Now, if I take a look at the templates NI provides when you invoke 'New...' from the file menu I find a framework named "Top Level Application Using Events." Clicking on this creates a little VI with an event structure and a stop button. When I run this it behaves just as expected.
Does anybody have a sense for what kinds of problems I'll run into if I decide to develop and event based VI with the base package? Is it worth the trouble?
Regards,
Josh
QUOTE(JReiner @ Sep 7 2007, 09:44 AM)
Hi All,
Regards,
Josh
My understanding is that existing code will run with the added functionality, but you will not be able to save any edits. You might want to try saving/building with some basic modifications before getting too far into a project.
QUOTE(TobyD @ Sep 7 2007, 01:02 PM)
Actually, I found that when right-clicking on the event structure there is no option to add an event case. Thanks for your help.
Regards,
Josh
