Starting with GOOP
Hello,
I want to begin with GOOP. So I found an entry in Tools->LabVIEW GOOP Wizard.. (I use LV 8.0.1)
post-7689-1189691412.png?width=400
Klicked it on and to create my first class. Saved it under "Auto" into project directory. An LLB was created. Ok.
post-7689-1189691717.png?width=400
After generating the next step, where I can Edit the calss reference.
post-7689-1189691825.png?width=400
So I should give the class name and put the enum into the reference.
post-7689-1189691929.png?width=400
And here the first question !!! Why it is a ENUM and not a string? Can I add more than one classes (using Add Item in Enum Properties) ? Why is it an enum?
In the next step I can edit the member data of the class. So I leaved only one string control inside the cluster and named it "Color".
post-7689-1189692152.png?width=400
After finishing the wizard I got following
post-7689-1189692209.png?width=400
I created a MainVI, where I want to use my class Auto and saved it in my project directory. Then I want to create an object. But I can't dropthe Auto Create.vi from wizard into my MainVI. So I opened Auto create VI and dropped the Icon into MainVI. It's OK, but can be better (that is no critic to wizard, but can be added into the wish list).
Auto Create is not executable, because I should init my member data with initials. Ok, I opened the VI and initialized my Color String whith "white".
post-7689-1189692632.png?width=400
Now, I want to get the actualy color of my Auto. So I created a public method GetColor.
post-7689-1189692921.png?width=400
Opened this VI and edited them. And edited the connector pane of them. I set the Color String to an output.
post-7689-1189693101.png?width=400
So I can get the color of my object "Auto". Cool!!!
post-7689-1189693170.png?width=400
It works. If I run my Main.vi I see that my Auto is "white".
Now I want to recolor my Auto in red. So I created a new public method "SetColor".
post-7689-1189693341.png?width=400
But forgotten to set the method type to "modify". After the method was created I want to delete them, BUT I SEE, THAT I CAN'T.
So my second question is: where I can delete methods in wizzard? That is my next wish, or can I do it anywhere?
So I opened the Auto.LLB and deleted the method SetColor in WinExplorer.
After them I created a new method SetColor with the right Method Type.
post-7689-1189693731.png?width=400
Modified the SetColorVI and the connector pane of them. Color is an input.
post-7689-1189693904.png?width=400
My mainVI shows as following now
post-7689-1189693969.png?width=400
Is all right? Am I on the right way?
Eugen
I'm in a bit of a rush, so I can only answer a little:
QUOTE(Eugen Graf @ Sep 14 2007, 12:34 AM)
The data in the enum is part of the datatype of the enum itself - this means that enums with different text in them are seen as different datatypes in LabVIEW, so your class is more defined. So, if you have two different classes, when you wire the refnum from one classes "create" into another classes "write" the wire will break. If you had a string, then it wouldn't.
No - that just changes the definition of one class. You need a separate datalog/enum for each class.
PS: welcome to OOP! When used appropriately, it's freakin' awesome!
QUOTE(crelf @ Sep 13 2007, 05:02 PM)
Thank you for your reply, crelf. I did understand why GOOP uses enum instead of a string reference.
My next big question is:
how can I inherit a new class, e.g. class "truck" from my class "auto"?
Eugen
QUOTE(crelf @ Sep 13 2007, 08:41 PM)
Hello crelf,
I think Endevos Tools are licensed and if I want to use them in my industial projects, I have to pay some money for it.
I think on an update from LV 8.0 to 8.5, but here I have to pay too.
What is free, good and good supported? Some ideas?
Eugen
QUOTE(Eugen Graf @ Sep 13 2007, 11:57 AM)
If these are 'industrial projects', wouldn't you expect to pay for support? The upfront money almost always means less cost in the long run.
QUOTE(dsaunders @ Sep 13 2007, 09:05 PM)
You are right, but I am not my own BOSS. I am an sole LV engineer in our company.
Eugen
QUOTE(Eugen Graf @ Sep 14 2007, 04:57 AM)
Oh - you're serious. If you really expect good support, then you should also expect to pay for it. That said, you'll get a lot of good support from us here at LAVA on pretty much any of the toolkits (this thread is an example). I just had a look at the Endevo website (I suggest you do the same) and found the community edition limitations:
QUOTE
Community Edition
The community edition is a free version of the tool. It has the same features as the Professional version but with the following limitations:
* It does not support the Endevo GOOP 3 class architecture.
* Maximum number of classes in a project is 10.
* There is no support.
* There is no update class to latest class template feature.
I wasn't able to find anything about "industrial" use.
QUOTE(crelf @ Sep 13 2007, 09:33 PM)
Thank you, crelf.
If I say good supported, I don't think on help from manufacturer (developer), I think much more on product bebugging and featuring and documentation. LAVA's support (help in developing) is great, so I don't need any else. :thumbup:
Surely, I will try out Endevo's tool.
What is GOOP 3 ?
Eugen
QUOTE(crelf @ Sep 13 2007, 10:11 PM)
To read more about the tool and the GOOP 3 check out the tool manual online:
http://www.endevo.se/files/downloads/products/gds/
View the section: GOOP 3 Provider and also OpenG Provider.
About licensing. The restrictions for the free Community Edition is exactly as Chris listed in a previous reply. The license allows commercial use, it does not restrict the usage compared to the Professional (non-free) edition. It is only a functional limitation and no Endevo support.
Jan Klasson
Endevo
QUOTE(Eugen Graf @ Sep 14 2007, 10:26 AM)
Oh no, :oops:
Endevos GOOP is only for LV 8.2.1 and later !!!
Is there nothing for 8.0.1 ?
Eugen
Yes, GOOP 3 is built on lvclass which came in 8.20.
For LV 8.0.1 your options are GOOP 1 and the free Wizard from NI which you already started using or our GOOP 2 (GOOP Inheritance Toolkit) but we don't have any free tools to offer.
On the other hand, why use 8.0.1? Upgrade...:-)
/Jan
QUOTE(Jan Klasson @ Sep 14 2007, 08:49 PM)
Which, on it's own, is a great reason to upgrade to 8.20 - you get the native LVOOP.
QUOTE(Eugen Graf @ Sep 13 2007, 07:10 PM)
Eugen
I feel your pain Eugen.
No one here (where I work) really appreciates the skill it takes to use LabVIEW effectively.
QUOTE(TG @ Sep 14 2007, 10:58 AM)
So on that note... I too am currently in that boat of either using the GOOP1 or the OpenGoop, as I am sure are many others out there... (and I do see lots of advantages in using OOP on the project I am currently working and future projects)
I've begun playing with them and am admittedly having a diffiicult time getting anything useable to work. ANd I've not had much success in finding explanations or documentation on their use and implementation. The begining of this thread looks like a really good start to what could help alot of people make the transition. Could we please continue along our originators course? And for those of you who are in the know, where are some good resourses that currently exist?
james
QUOTE(jccorreu @ Sep 21 2007, 03:22 AM)
james
Sorry James, I will first continue this or a new topic related to GOOP- if my boss pay an update to 8.5
And I really understand you and me :rolleyes: , who have "no money" and have to use unchildable classes :headbang:
Eugen
