Select Default Connector Pane in Tools-> Options-> Front Panel
Actually there are both empty new VIs and VIs created from some sort of VI template. I think the VIs created from templates should always use the template default as the user selected connector pane may not always fit to the template. For example LabVIEW class methods are created from templates e.g. dynamic dispatch template, static dispatch template and accessor method tempaltes.
Tomi
  • 10 months later...
QUOTE (yen @ Oct 8 2007, 03:56 PM)
I just read the Noel's Feature Brainstorming entry here, submitted my INI file and suggested that Darren's example VI be incorporated into the Options Dialog.
I also went looking in the WIKI for the defaultConPane setting and couldn't find it (As Norm often says "search sucks"). I added defaultConPane to the Misc options page
Let's see what happens...
