Matheus Posted October 16, 2007 Report Share Posted October 16, 2007 I´m using the cFP 2020 and de module AI-118, this device have 8 channels, I cant obtain a rate better than 50s/s!! What can I do? Quote Link to comment
LAVA 1.0 Content Posted October 16, 2007 Report Share Posted October 16, 2007 QUOTE(Matheus @ Oct 15 2007, 09:56 AM) I´m using the cFP 2020 and de module AI-118, this device have 8 channels, I cant obtain a rate better than 50s/s!!What can I do? http://lavag.org/old_files/monthly_10_2007/post-8901-1192456491.jpg' target="_blank"> How is the performance without the SV read? Then how does it perform without the TC reads? Ben Quote Link to comment
Matheus Posted October 16, 2007 Author Report Share Posted October 16, 2007 Without the SVs it continous with the same rate, When I decrease de time of Timed Loop, the startup application STOP and break all the cFP System. The mean of TC reads is Thermocouple reads? The minimum dt of TL was 20ms! Quote Link to comment
LAVA 1.0 Content Posted October 16, 2007 Report Share Posted October 16, 2007 QUOTE(Matheus @ Oct 15 2007, 11:17 AM) Without the SVs it continous with the same rate, When I decrease de time of Timed Loop, the startup application STOP and break all the cFP System.The mean of TC reads is Thermocouple reads? The minimum dt of TL was 20ms! I can't say I have ever seen a cFP run that fast. I remeber reading a post by an NI AE that spoke of a setting in MAX affecting the acq rate. And yes TC = Thermocouples Ben Quote Link to comment
Matheus Posted October 16, 2007 Author Report Share Posted October 16, 2007 QUOTE(neB @ Oct 15 2007, 01:29 PM) I can't say I have ever seen a cFP run that fast.I remeber reading a post by an NI AE that spoke of a setting in MAX affecting the acq rate. And yes TC = Thermocouples Ben I'm Trying to separate the Readers in diferents loops and FIFOs. I think that solution may be rigth! Have u any idea? Quote Link to comment
Neville D Posted October 16, 2007 Report Share Posted October 16, 2007 In the past, I found that reading all channels required in a single read is faster than reading individual chans one at a time. Also, if I remember correctly, the TC module was much slower to read than the other module types... the reason escapes me at the moment.. this was about 3 yrs ago. Neville. Quote Link to comment
Matheus Posted October 16, 2007 Author Report Share Posted October 16, 2007 QUOTE(Neville D @ Oct 15 2007, 03:32 PM) In the past, I found that reading all channels required in a single read is faster than reading individual chans one at a time.Also, if I remember correctly, the TC module was much slower to read than the other module types... the reason escapes me at the moment.. this was about 3 yrs ago. Neville. Thanks for your atention, It's true, the rate of TC Modules are more slow than AI aq. http://www.ni.com/pdf/manuals/372056a.pdf But I can't understand this manual, it says: " The all-channel sample rate of the cFP-AI-118 is 10.42 kHz with no filtering. If you enable filtering on any channel, the all-channel sample rate is 3.45 kHz." I am already using separately loops to read AI and TC signal. In NI forum, i found another people with the same problem, i called to NI Support in Brazil, but they unknow this problem! BUT, in any event, THANKS A LOT. IF ANY BODY CAN HELP ME..... I WILL BE ETERNALLY GRATEFUL. Quote Link to comment
