Looking for "Demo Read Voltage.vi"
djp_eng
Judging from the link you provided, I'd say you will not find this example in your current LV-version.
The manual seems to be LV 5. The DAQ-driver in that time was what is now called traditional DAQ. The current (and much better) driver is now DAQmx.
I suggest you have a look at the examples for data-aquisition which you can find inside the NI-example-finder.
Jens
BTW, why post the same question twice??
QUOTE(djp_eng @ Nov 17 2007, 02:44 AM)
Have seen several references to a "Demo Read Voltage.vi"...
IIRC this VI comes with the LabVIEW Basics I course examples and is to be used if you don't have DAQ hardware.
It doesn't do much more than generating a random value.
If you only need it as a sub-VI to open some example, it might be easy to replace it by a simple VI of your own.
