Aitor Solar Posted November 21, 2007 Report Posted November 21, 2007 Adding a description to a polymorphic VI should be obvious but... well... I can't find it. I've been doing it through the poly VI reference, but sure there is an easier way, isn't it? Saludos, Aitor Quote
Ton Plomp Posted November 21, 2007 Report Posted November 21, 2007 QUOTE(Aitor Solar @ Nov 20 2007, 10:22 AM) Adding a description to a polymorphic VI should be obvious but... well... I can't find it.I've been doing it through the poly VI reference, but sure there is an easier way, isn't it? http://lavag.org/old_files/monthly_11_2007/post-1450-1195550434.jpg' target="_blank"> Saludos, Aitor Right click an instance -> Open Polymorphic VI <ctrl-I> -> Documentation Ton Quote
Aitor Solar Posted November 21, 2007 Author Report Posted November 21, 2007 QUOTE(tcplomp @ Nov 20 2007, 11:19 AM) Right click an instance -> Open Polymorphic VI<ctrl-I> -> Documentation All right, is a shortcut to File -> VI Properties. You know, I always use a right-click on the VI icon and then "VI properties" and that doesn't work with polymorphics. Thanks, Ton. I fell stupid now Saludos, Aitor Quote
Bobillier Posted November 21, 2007 Report Posted November 21, 2007 Have you just try to open the poly instance (ex:Yourvi(poly).vi) and just make Files\ property\documentation . That run fine for me in 7.0 Eric Quote
