ricardo_apg Posted November 21, 2007 Report Posted November 21, 2007 Hello!!! I am using Labview 8.0 to communicate with different devices, from keithley487, keithley248, Quadtech 1920 among others. What is happening and that I have trouble communicating with these devices through a converter GPIB-USB, this on my PC because I have a portatil a friend that I have exactly the same drivers and everything else that works perfectly and not giving any kind of error. Ja tried everything, from installing drivers older, and recent same way without the desired effect. Se ha someone who already has a problem of gender, and I can clarify please immensely, thank you! Quote
TobyD Posted November 21, 2007 Report Posted November 21, 2007 QUOTE(ricardo_apg @ Nov 20 2007, 03:55 AM) Hello!!!I am using Labview 8.0 to communicate with different devices, from keithley487, keithley248, Quadtech 1920 among others. What is happening and that I have trouble communicating with these devices through a converter GPIB-USB, this on my PC because I have a portatil a friend that I have exactly the same drivers and everything else that works perfectly and not giving any kind of error. Ja tried everything, from installing drivers older, and recent same way without the desired effect. Se ha someone who already has a problem of gender, and I can clarify please immensely, thank you! I'll ask the obvious question...Did you set the GPIB addresses of your equipment to whatever they are set to in your code? Quote
Topher Posted November 21, 2007 Report Posted November 21, 2007 What kind of GPIB-USB converter are you using? There are issues with the Agilent converter's drivers working with NI's drivers. Quote
MikaelH Posted November 21, 2007 Report Posted November 21, 2007 I have had problems with Keithleys GPIB driver, but no problem using NI's USB to GPIB cable. Remove all GPIB card uninstall all drivers and just install NIs USB-GPIB cabel, that should work. //Mikael Quote
ricardo_apg Posted November 21, 2007 Author Report Posted November 21, 2007 Hello!!! I am using Labview 8.0 to communicate with different devices, from keithley487, keithley248, Quadtech 1920 among others. What is happening and that I have trouble communicating with these devices through a converter GPIB-USB, this on my PC because I have a portatil a friend that I have exactly the same drivers and everything else that works perfectly and not giving any kind of error. Ja tried everything, from installing drivers older, and recent same way without the desired effect. Placed addresses their equipment properly. What is happening is that I can get the values of the readings of equipment, but in relation to control the unit through the PC's me erro.Por example in Keithley487 the error that gives me is "IDDCO." Converter used and NI GPIB-USB-A. If someone who already has a problem of gender, and I can clarify please immensely, thank you! Quote
