cFP DI frequency
thieumat
Hi everybody!
I have a cFP DI that reads a pseudo-periodic pulse
how could I put this signal on a timeline to measure the length of the 1 pulse ?
I've tried to put it on a digital waveform but it seems to need an array of 8 signals, I don't realy understand
Any others methods are welcome
I have lavbiew 8.2 dev suite
Regards
matthieu
How fast is this pulse? I seem to remember that the cFP poll cycle of its I/O module is relatively slow (I think it was a few ms), so if you have a faster pulse you might have a problem.
As for measuring the length, all you need is an FP Read VI which will output a single boolean and a loop with two shift registers - one to remember the previous value of the DI and one to remember the last time of the change. When you detect that the input changed (by comparing it to the previous value), you use the Tick Count primitive to get the current time and substract from it the previous time to get the number of ms that passed and that's your pulse length.
You might get higher accuracy with a timed loop, but I'm not sure if it's supported on the cFP.
QUOTE(Yen @ Nov 29 2007, 12:26 PM)
Yes it is supported but it is not any faster.
For fast signals I have used a counter timer module to measure the period.
It also sounds like the original questioner, is reading from all of the DI lines and not just one. If this is the case, either change the code to read only the single DI line or use an index array to pull out the channel of interest and then follow Yair advice.
Ben
another little question ;p
suppose that the frequency of my pulse is knowed, said 1Hz, easy to count
in MAX I can see it easealy on the specified channel of my cFP DI : 1 ... 0 ... 1 ... with the good frequency
but when I put a fp read and a indicator in a simple while loop the frequency is shorter and realy instable, sometimes 10Hz, sometimes 200Hz ...
I've tried with a delay between eatch loop, in a timed structure ... always the same
but in MAX it's still good !
is there is a diffrence between MAX reading and the fp read ?
If the pulse is a stable 1 Hz and your TCP connection is consistent, then I see no reason why you shouldn't see the same thing in LabVIEW as you do in MAX. I suggest you upload the VI you're using to do this.
