Extended variant custom probe
osvaldo
Hi to all you,
I'm developing an application that use variants and variants atrributes.. and the default labview probe for the variant data type is very ugly... so I started using the probe by tcplomp i find in the CR... Great work! But does not display the attributes of the variant...
Well, to cut a long story short, I have extended the code from tcplomp to add this functionality.
The probe in attachment display the data part and all the attributes defined for the variant under test, recursively. If an attribute or a sub data part is a variant, all his attribut will be browsed.
Also supported time stamps and all type of waveforms.
Regards!
Osvaldo
Download File:post-457-1197990179.zip
QUOTE(osvaldo @ Dec 18 2007, 04:03 PM)
Thanks,
But are you sure you used the latest version (1.1.0 dated May 2007)?
Because that would add attributal recursive.
I had a quick look at your code, and saw you dug into Waveforms (that's brave) :thumbup:
Oh, gosh! You're right!
I have not noticed the upgrade! :oops:
I missed the opportunity to have some code already written! ...
Well! I exercised a bit with the custom probe! :P
Regarding waveforms ... I had to do it when I discovered that time-stamps are a sub-type of waveform! :blink:
The only waveform that the probe does not browse is the Dinamic subtype...
I do not know how to create one to verify the probe! Suggestions?
Regards
Osvaldo
QUOTE(osvaldo @ Dec 21 2007, 02:52 PM)
Yes I http://forums.lavag.org/downloads-file63.html' target="_blank">updated it, but in the process something happened you might dislike, it's upgraded to LabVIEW 8.5 because of the use of recursive LVOOP.
