Listbox Weirdness
Create a system multi-column listbox. Fill in several rows with some data.
Set the properties Active Cell and Edit Position to a row in the middle of the ones you populated.
Set the value to that same row.
Set the key focus to true.
Create a simple while loop to keep the VI running after all these setting are applied.
Run the VI. The row you set should be selected.
Use the up/down arrow keys to move to another row more than 2 rows away.
Stop the VI
Run the VI again.
Use the arrow keys to move the selection again. Instead of moving relative to the programmatically selected row that is highlighted, it will jump to the row that was (up/down) from the row you moved to right before you last stopped the VI.
Why does it do this? Why does it remember the last selection you navigated to? How can I override this so the selection I set programmatically is the one it will move relative to when the use uses the arrow keys?
Is this a bug?
-John
Download File:post-2411-1198024019.vi
QUOTE(jlokanis @ Dec 21 2007, 10:50 PM)
Hello? Is this just obvious to everyone else or is there just no one who cares?
No, it's not obvious, and yes I care.
I can't find an explanation. I only noticed that the 'Edit position' isn't updated by the property.
  • 3 years later...
