Thang Nguyen Posted January 15, 2008 Report Posted January 15, 2008 Hi, I have an issue and need the recommendations form you. Currently, I am working on an old project which my company did it with LV 7.0. This is a big project and take a lot of time to develop. This is the reason why we try to find a way to move the program from 7.0 to 8.5 without rewrite the whole thing. The problem is this project use DSC and there are a lot of tags. My question is there is anyway to move the program from LV 7.0 to LV 8.5 by converting the tag engine from 7.5 to 8.5. This relates to another issue as the DSC VI used to read and write data. I hope that by your experience you can give me some suggestions. I highly appreciate your time of reading and answering my question. Warm Regards, Thang Nguyen Quote
LAVA 1.0 Content Posted January 16, 2008 Report Posted January 16, 2008 QUOTE(Thang Nguyen @ Jan 14 2008, 07:12 PM) Hi,I have an issue and need the recommendations form you. Currently, I am working on an old project which my company did it with LV 7.0. This is a big project and take a lot of time to develop. This is the reason why we try to find a way to move the program from 7.0 to 8.5 without rewrite the whole thing. The problem is this project use DSC and there are a lot of tags. My question is there is anyway to move the program from LV 7.0 to LV 8.5 by converting the tag engine from 7.5 to 8.5. This relates to another issue as the DSC VI used to read and write data. I hope that by your experience you can give me some suggestions. I highly appreciate your time of reading and answering my question. Warm Regards, Thang Nguyen MAX has a utility to convert your SCF and histories. The read tag VI will get converted to shared variable reads. If y have "Read Tag" VI's in a loop that use tag names to read from, then you can use datasockets reads to do the same thing. Dynamic events can be registered for tags if required. Ben Quote
Thang Nguyen Posted January 19, 2008 Author Report Posted January 19, 2008 Hi, I now did migrate the DSC tag-engine server from 7.0 to 8.5 already. What I need to know now is how to deply in programmatically. The server will not run untill I call it, and I think this a good idea instead let it always run. Thank you for your time, Thang Nguyen Quote
