Tables in Labview
Hi everybody...
I have a table like that in the picture below...
The program has to read a certain value in the table for example the first cell (10/1/2008 in the picture above)..
then compare this date with the date of computer so if they are the same, the program will run an order...
and if not, the program will exit...
so my question is how to make the program make this reading of table?
Thanks
QUOTE(yasmeen85 @ Jan 24 2008, 11:55 AM)
Thanks for your replying...
But I'm using Labview 8.0 so the file can't open...
Can you please attach the example in version 8.0 or put the pictures of it..
Thanks again
I just reformatted my system and only have 8.5 installed. The picture I already posted is the example. It just shows you how to convert the data from a string (pulled from your table) into a timestamp.
QUOTE(TobyD @ Jan 25 2008, 01:25 AM)
Thanks again for your replying...
But I don't have a problem in changing the timestamp to a string or vice versa...
My question was is how to make the program to read the array, it will read the first cell in the array which is (date=10/1/2008) then compare this date with the date of system. If they are the same, the program will go to next cell which is (quantity=5) and run an order.
then the next day the program will read the next cell in the date (22/1/2008) and repeat the procedure above...
But if the date was not the same of the system, then program will exit...
So can I do this by Labview??
I hope the idea is clear now and I'm waiting for your replying or any question...
Thanks
QUOTE(yasmeen85 @ Jan 25 2008, 12:59 PM)
You don't have to read per single cell. You can read the whole file at once, there are functions for that. After reading the whole file you can perform your described algorithmn on the data - which will have to be performed cell-by-cell.
BTW reading from an Excel file is difficult, but there is a standard function to read from a CSV file or Tab separated file (also creatable with Excel).
Joris
