reading from csv file.
in this attached vi, i want to read data from a csv file. The problem is, that i can not picture the right format.
In the first coloum i only get the the 19, in the second 14 and so on of 19.02.2004 13:00:00,14.5500,2.6120,423.5600,1.2561,1.9590
Couldn't upload the csv file.
Would be great, if anybody could help.
Thanks, Jennifer
QUOTE(jennifer @ Jan 25 2008, 06:04 AM)
Thanks, Jennifer
It would help if you'd attached a sample of your csv file.
Based on your description, processing the file as a double won't give you the proper first value as it's a timestamp and not a double. You'd have to process everything as a string array to preserve the timestamp. After that you'll have to process the strings.
Depending on what you're doing, there may be better ways of processing the csv file.
QUOTE(Tim_S @ Jan 25 2008, 01:12 PM)
this new vi contains a few lines of the csv file. It works better now with strings. Thanks for your hint. I want to show the first two strings in a row in a diagram. How can this be realized?
Thanks for your support.
QUOTE(jennifer @ Jan 28 2008, 11:58 AM)
Jennifer,
I made a few additions to your VI. I don't know if this is exactly what you were looking for but the VI now lets you select a row then gives you the first two elements that are comma seperated.
Hope this helps.
Steve
You could open the file and use "Read from Text File" to read n number of lines. You'll have to right-click on the primative function and check Read Lines to do this. The Spreadsheet String to Array primative would also be useful.
Tim
QUOTE(Tim_S @ Jan 28 2008, 07:53 PM)
Tim
Why do sara and jennifer post quite similar requests here. I get this feeling that sara learned from the reactions and now got an identity change and tries to at least show that she did a little work before asking questions. Still!!
Rolf Kalbermatter
QUOTE(rolfk @ Jan 29 2008, 10:55 AM)
Rolf Kalbermatter
That's exactly what I thought! It must either be the same person, or they have the same professor. :gathering:
QUOTE(TobyD @ Jan 29 2008, 02:55 PM)
And if the first is true I wonder if the name is just to try to get more likely help as a HH :laugh:
Rolf Kalbermatter
QUOTE(Steve_Brooks @ Jan 28 2008, 07:35 PM)
Jennifer,
Hope this helps.
Steve
Hi Steve,
yes, that helps. Thanks a lot. I tried to display the values in a graph with the date as the x-scale and the temperature as the y-scale. Didn't worked out. Do you have a solutuion?
