PatNN Posted February 2, 2008 Report Posted February 2, 2008 Ability to run selected section of the block diagram without having to run the entire VI. This would be a useful debugging feature. Right now I have to select the portion I'm interested in, and create a new VI out of it (or a subVI, with the drawback that I can't easily undo the changes to the original VI) Would be nice to just be able to select a section of the block diagram of interest, interactively initialize the inputs or optionally use the default values, and run it. Quote
Ton Plomp Posted February 2, 2008 Report Posted February 2, 2008 QUOTE(PatNN @ Feb 1 2008, 03:28 AM) Ability to run selected section of the block diagram without having to run the entire VI. This would be a useful debugging feature.Right now I have to select the portion I'm interested in, and create a new VI out of it (or a subVI, with the drawback that I can't easily undo the changes to the original VI) Would be nice to just be able to select a section of the block diagram of interest, interactively initialize the inputs or optionally use the default values, and run it. Well that is why you put stuff in one VI, to do unit tests and stuff. Ton Quote
LAVA 1.0 Content Posted February 2, 2008 Report Posted February 2, 2008 QUOTE(PatNN @ Jan 31 2008, 09:28 PM) Would be nice to just be able to select a section of the block diagram of interest, interactively initialize the inputs or optionally use the default values, and run it. You can http://cnx.org/content/m12210/latest/' target="_blank">create a sub-vi from a section of a block diagram. The input and output connectors will be created for you. Quote
jzoller Posted February 2, 2008 Report Posted February 2, 2008 I have to agree with PatNN on this one. That would be a feature I would use. On a more general note, workarounds != native support, and should never be used as an excuse for not providing native support for good features. Joe Z. Quote
LAVA 1.0 Content Posted February 2, 2008 Report Posted February 2, 2008 QUOTE(tcplomp @ Feb 1 2008, 03:03 AM) Well that is why you put stuff in one VI, to do unit tests and stuff.Ton Yes, in 90% of the cases, I agree. Strangely enough, I just posted a similar feature request at another forum There are cases where you have to test your vi as embedded into the final code, but don't want to run the entire thing to get to where you want to be... Now, you have to remember, this is the "Wish List" section... I'm sure this feature would be a sunnovogun to implement... But hey, we gatta keep them NI folks busy!.. Good suggestion! Quote
Daklu Posted February 20, 2008 Report Posted February 20, 2008 QUOTE(PatNN @ Jan 31 2008, 06:28 PM) Ability to run selected section of the block diagram without having to run the entire VI. This would be a useful debugging feature. I'd be thrilled if I could simply ignore sections of code while I'm debugging. For instance, if I'm stepping through code that contains parallel loops I'm constantly being shifted around the block diagram to view the next code step when I'm only interested in the code in *this* loop. It gets frustrating. Quote
crelf Posted February 20, 2008 Report Posted February 20, 2008 QUOTE(Daklu @ Feb 19 2008, 02:33 PM) ...if I'm stepping through code that contains parallel loops I'm constantly being shifted around the block diagram to view the next code step when I'm only interested in the code in *this* loop. So you want a diagram disable structure that disables the code outside the structure, instead of inside it? That's a freakin' awsome idea! :thumbup: Quote
Daklu Posted February 21, 2008 Report Posted February 21, 2008 QUOTE(crelf @ Feb 19 2008, 12:11 PM) So you want a diagram disable structure that disables the code outside the structure, instead of inside it? That's a freakin' awsome idea! :thumbup: Wish I could lay claim to it, but that's actually the op's idea. It's a little difficult to explain what I'm asking for. I want to be able to select or otherwise indicate the code segment I am interested in. All the code is executed but only the selected code is "debugged." Any non-selected code that executes while I'm stepping through my selected code isn't highlighted, doesn't display values, doesn't change my view to that to that location, etc. I created a vi that illustrates the problem I'm hoping this would address. Open the block diagram, click Highlight Execution, and step through the math loop. Quote
crelf Posted February 21, 2008 Report Posted February 21, 2008 QUOTE(Daklu @ Feb 20 2008, 12:18 AM) Wish I could lay claim to it, but that's actually the op's idea. Meh - I like my idea better Quote
robijn Posted February 21, 2008 Report Posted February 21, 2008 I wanna change values in wires while debugging ! Joris Quote
crelf Posted February 21, 2008 Report Posted February 21, 2008 QUOTE(robijn @ Feb 20 2008, 11:34 AM) I wanna change values in wires while debugging ! I wanna gold-plated toilet seat! Quote
dbyers3 Posted February 21, 2008 Report Posted February 21, 2008 QUOTE(crelf @ Feb 20 2008, 11:17 AM) I wanna gold-plated toilet seat! Try ebay.com I'm sure they have one. :laugh: Quote
