Returning a value from a VI that was called by reference
QUOTE(george seifert @ Feb 21 2008, 10:04 AM)
What's the proper way to return a value (Boolean in this case) from a VI that was called by reference (with an invoke node)? I suppose using a global is possible, but I've more or less shuned them.
If it's a strictly-typed call, just wire it out, if it's not strictly-typed, you can get a referece to the FP node (and its' value) by name using a VI reference method.
Please look into LVx
http://forums.lavag.org/LVx-Exported-LV-Fu...lity-t9437.html
This merges both what AQ is talking about and the flexibilty of LVOOP.
For your situation, you'll have a chid of the LVx object with the needed return datatype be the data type inside of the object.
When you send the command to your client VI to return the value, it will populate the object passed to it with the data and pass it back to the other VI where you can pull it out of the object.
There is a example of this in it's demo
-Norm
