how to transfer value to second vi
Hi,I have one question.
I have two .vis. Is possible read value of any indicator from first .vi and this value to use like control in second .vi??
For example.
The first .vi is linked to incremental encoder. And I want to read the signal from encoder in the second .vi.
an easy solution:
you can add a global variable an write the value into (you can use a shared variable, too)
another solution:
using vi server, or reference the vi, get all front panel indicators and select the one you want
-timo
QUOTE (T_Schott @ Mar 16 2008, 11:07 AM)
  Quote
an easy solution:
-timo
ok, i have created global variable an writed the value into. But now, i dont know how to use this variable in secon vi :(
thank for your help
