Print out Project Explorer
QUOTE (ASTDan @ Apr 21 2008, 05:01 PM)
Hello,
Does anyone know if it is possible to print out your Project Folder for documentation purposes?
Is there another method/software tool of easily documenting the all the files that you are using for your applicaiton?
Thanks
Dan
I often wondered why Windows doesn't let you do this.
In DOS, just type at the command line "dir > whatever.txt" and the contents of the current directory will be printed to the text file whatever.txt. This has the advantage of giving you the file sizes in exact bytes.
Richard
