Print out Project Explorer
Hello,
Does anyone know if it is possible to print out your Project Folder for documentation purposes?
Is there another method/software tool of easily documenting the all the files that you are using for your applicaiton?
Thanks
Dan
QUOTE (ASTDan @ Apr 21 2008, 05:01 PM)
Hello,
Thanks
Dan
I often wondered why Windows doesn't let you do this.
In DOS, just type at the command line "dir > whatever.txt" and the contents of the current directory will be printed to the text file whatever.txt. This has the advantage of giving you the file sizes in exact bytes.
Richard
QUOTE (MikaelH @ Apr 21 2008, 10:49 PM)
You can use the property nodes to do this
That looks like the way to go. Instead of displaying the project in memory how do you specify a project via file name?
Thanks
Dan
QUOTE (ASTDan @ Apr 23 2008, 06:19 AM)
Thanks
Dan
Just parse the project.lvproj file. It's easy readable XML.
Cheers,
Mikael
