Michael Aivaliotis Posted May 6, 2008 Report Posted May 6, 2008 why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation. Quote
Bjarne Joergensen Posted May 6, 2008 Report Posted May 6, 2008 QUOTE (Michael_Aivaliotis @ May 5 2008, 09:02 AM) I like this idea. Along the same lines (or maybe this is hijacking), why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation. I can't se the picture of what you are talking about. What is wrong ? regards Bjarne Quote
crelf Posted May 6, 2008 Report Posted May 6, 2008 QUOTE (Michael_Aivaliotis @ May 5 2008, 03:02 AM) why does a 1D array always become a 2D on for loop borders? Why can't we concatenate a 1D array at the border. It seems that tunnel has the potential to do a lot more than it can right now in regards to array manipulation. I also can't see a picture about what you're talking about, but I agree. If this is implimented, we need to consider making it obvious at the tunnel that this is happening (of course), and there's not much real estate on of those little nodes - it'll be quite a challenge for the NI design team Quote
Jim Kring Posted May 6, 2008 Report Posted May 6, 2008 This is what Michael's talking about: Notes: You can't just build a 2D array and reshape it to 1D (outside the loop), since each 1D array might be a different length. This should also work for strings :thumbup: Quote
orko Posted May 7, 2008 Report Posted May 7, 2008 I love it! A simple right-click:concatenate option on the exit tunnel (like the "build array" primative, which is basically the extra code you're trying to eliminate, right?) would be very nice here. I don't see why this would have to be limited to just 1D outputs though. I can see cases with 2D arrays inside a For loop where I would want to concatenate vs. build a 3D array as well. Quote
Yair Posted May 8, 2008 Report Posted May 8, 2008 I wanted something like this for a long time as well. QUOTE (Jim Kring @ May 5 2008, 05:14 PM) This should also work for strings :thumbup: If you're refering to concatenating different strings into a single one, you can sort of do that - build them into an array and then concatenate the array: Quote
