Context Help truncated
There's a config token for this. In your config file put:
MaxHelpDescLength=10000
or whatever length you want. This will set the maximum number of characters that will be displayed before truncation in the Context Help. If set to a non-positive number (aka -1), then there will be no max. If set to 50 or less, then 50 will be the max.
Of course, this token won't be set on other machines that you install into. If you're making a built app with Context Help, then you can put this token into your app's custom config file. If this is a toolkit that you're building, your readme file may need to tell your users to add the config token. ... assuming of course that you want a CH that is that long. That is highly unlikely. If you've got that much text, it probably goes in the help for the control/indicator/VI.
Another option is to create your vi documentation in Word and save as a web page (.htm file). Then link to it as the Help path under vi properties>documentation. The Detailed help link in the Context help window is a link to the document. Click on the link and the document will come up in your web browser. Since it is now a .htm file I don't think you will run into size restrictions. Also, while the vi is running, this document will come up in the browser when the operator presses the F1 key.
