Chelectro Posted June 4, 2008 Report Posted June 4, 2008 I have a 6229 PCI DAQ connected to a CB-68LP connecting(PIN68 & PIN33)Analog Inputs. The electrical measure is an AUDIO differential signal, How can I performed a MATH function (V+)-(V-)? I can see both signal at 180 degrees dephase please see attachement. Quote
Tim_S Posted June 5, 2008 Report Posted June 5, 2008 QUOTE (Chelectro @ Jun 3 2008, 10:13 AM) I have a 6229 PCI DAQ connected to a CB-68LP connecting(PIN68 & PIN33)Analog Inputs. The electrical measure is an AUDIO differential signal, How can I performed a MATH function (V+)-(V-)?I can see both signal at 180 degrees dephase please see attachement. If you are acquiring the signal as differential, then you will automatically get signal + with respect to signal -. If you can see both signals, then you are not acquiring a differential signal. Without looking up the channels, it sounds as if you have the wiring correct (the signal + should be connected to channel 0 and the signal - should be connected to channel 8). Tim Quote
LAVA 1.0 Content Posted June 5, 2008 Report Posted June 5, 2008 I agree with everything Tim has to to say (right up until about 8:00 tonight) Ben Quote
