Norm Kirchner Posted August 4, 2008 Report Posted August 4, 2008 I figured adding a context menu for an XControl would be pretty obvious but I'm pulling blanks here. Anyone w/ experience doing this because NI search gives nil Quote
Yair Posted August 4, 2008 Report Posted August 4, 2008 Um, you right click the control in the facade VI and edit its context menu? It looks like each control in the facade VI has its own context menu. Quote
LAVA 1.0 Content Posted August 4, 2008 Report Posted August 4, 2008 QUOTE (Yair @ Aug 3 2008, 06:58 PM) Um, you right click the control in the facade VI and edit its context menu?It looks like each control in the facade VI has its own context menu. Shortcut Menu activation for each pane and control. On the VI you make sure all controls don't have their default LabVIEW shortcut menu. Unfortunately I haven't found a property to get to that VI property, I advice to edit your XControl template to remove that option so all facade VIs have a clear context menu. Ton Quote
