Context Menu for XControl
QUOTE (Yair @ Aug 3 2008, 06:58 PM)
Um, you right click the control in the facade VI and edit its context menu?
It looks like each control in the facade VI has its own context menu.
Shortcut Menu activation for each pane and control.
On the VI you make sure all controls don't have their default LabVIEW shortcut menu.
Unfortunately I haven't found a property to get to that VI property, I advice to edit your XControl template to remove that option so all facade VIs have a clear context menu.
