CaseyM Posted August 9, 2008 Report Posted August 9, 2008 Hi all, Is it at all possible to call a Matlab DLL (i.e. MCR) in LabVIEW RT? From what I've seen it doesn't appear so. If, indeed, it is not possible, does anyone have any insights as to how else one might call Matlab code in LabVIEW RT? -Casey Quote
Yair Posted August 9, 2008 Report Posted August 9, 2008 LabVIEW has a MATLAB script node, which can run MATLAB code, but since I never used it (or MATLAB, for that matter), I can't tell you if it will work in RT. A search would be in order. Quote
Rolf Kalbermatter Posted August 26, 2008 Report Posted August 26, 2008 QUOTE (cmay @ Aug 7 2008, 07:10 PM) Quote Hi all,Is it at all possible to call a Matlab DLL (i.e. MCR) in LabVIEW RT? From what I've seen it doesn't appear so. If, indeed, it is not possible, does anyone have any insights as to how else one might call Matlab code in LabVIEW RT? -Casey It's probably not possible at all. In order to run a Matlab DLL you have to have installed the Matlab runtime library or how it is called. And this library will likely rely on C runtime and Windwos API calls that are not present in the RT system. In addition a Matlab DLL would not even be compatibale at all with the VxWorks based realtime targets so the is no chance to get it to work there I guess. That is unless Matlab can create full C code for its scripts and you can get that to compile in the targets systems compiler tool chain. All in all not pretty work for sure if it is possible at all. Rolf Kalbermatter Quote
Neville D Posted August 26, 2008 Report Posted August 26, 2008 QUOTE (cmay @ Aug 7 2008, 04:10 PM) Quote If, indeed, it is not possible, does anyone have any insights as to how else one might call Matlab code in LabVIEW RT?-Casey I was going to suggest using the mathscript node (that can run a large percentage of m code in the LV environment), but it is unsupported on RT. So your out of luck apart from translating it into LV code. Is it a lot of code? N. Quote
CaseyM Posted August 27, 2008 Author Report Posted August 27, 2008 Thanks for the replies. I was pretty certain that it wouldn't work. We decided to just to transfer the raw data off the cRIO and to the Matlab processing then. -Casey Quote
